• 27.03.2026, 03:50
StatiS
Temperature and flow sensor question
Montag, 12. April 2010, 18:45
Can I use this flow sensor http://shop.aquacomputer.de/product_info…roducts_id=2294 and this temperature meter http://shop.aquacomputer.de/product_info…roducts_id=2291 in the following way:
radiator outlet ->male to male(http://specialtech.co.uk/spshop/customer…cat=1616&page=1)->flow sensor->male to male->temperature sensor->compression fitting 3/8" ID-1/2"OD->tubing 3/8 ID"-1/2OD"
b0nez
Dienstag, 13. April 2010, 00:09
as long as the compression fitting behind the teperature sensor has an G1/4" thread there should be no problem
greetings
b0nez
:rolleyes:
