• 23.02.2026, 06:35
osborne3
Flow Metre Possibly Rattling
Sonntag, 9. Mai 2010, 08:33
Hey everyone I just finished my new watercooled build and there seems to be a rattle coming from my pump and flow metre area that is really annoying here is a video of of how it sounds (Turn Volume UP) Anywho I thought I would check here to see if anyone else has got a rattle from there Aqua Computer flow metre or from there XSPC mounted Swiftech MCP355, Or if anyone has any ideas on what it could be. On first assumptions I suspect my flow metre.But can't be sure. Thanks for help :D
Flexerl
Montag, 10. Mai 2010, 00:09
Definitely the flow metre. Had the same issue until I replaced it.
osborne3
Montag, 10. Mai 2010, 09:56
Ok so can I get it RMA'd you reckon? or do I just have to fork out the cash for another?
Flexerl
Montag, 10. Mai 2010, 10:11
RMA. You're still within warranty, right?
osborne3
Mittwoch, 12. Mai 2010, 03:58
hmm yeh most likely, I bought it about a month ago.
