• 01.04.2026, 17:10
GourouLubrik
Aquaero 4 discontinued ?
Montag, 17. Mai 2010, 18:58
Hi there,
I'd like to ask a maybe stupid question, but i'm asking it anyway :
What's the reason for all version of Aquaero being out of stock ? ?(
It's the case on aquacomputer shop, it's the same situation with many european e-tailers...
Is the product discontinued ? Are you preparing an aquaero 5 ? Do you have trouble producing them ?
I did many research on monitoring devices for watercooling, and concluded that Aquaero 4 LT with powerbooster was fitting my needs... but I just don't find a single place to buy it...
Thanks for your explaination in advance.
b0nez
Dienstag, 18. Mai 2010, 00:40
Due to the economic crysis last year AC cant get all electronic parts they need to build the Aquaero.
This is also the reason why the new PA ins't out yet.
:rolleyes:
GourouLubrik
Dienstag, 18. Mai 2010, 18:21
Thanks for this information.
I hope you can it fixed soon =/
Best Regards,
GourouLubrik
Montag, 31. Mai 2010, 14:18
You (& Aquatuning) finally got some back in stock !
So I bought 1 aquaero LT with powerbooster & 2 aquaero VFD with powerbooster for a friend.
Long live to the finest watercooling monitor/regulator in the world :D
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »GourouLubrik« (31. Mai 2010, 14:19)
