• 22.05.2026, 11:00
Matt
Full cover waterblock for ATI HD 5970 (BLACK EDITION) -----> Need advice and help <------
Samstag, 31. Juli 2010, 19:13
I'm looking for the full cover waterblock for the HD 5970 Black Edition ( XFX production), someone of the staff could link me the exactly product i've to order? :D
I've seen there are 3 different solution in the shop, could someone gently tell me the difference? and these solution fit perfectly the BLack edition one? ?(
Maybe and would be nice if you can link me the "fitting" for this waterblock :thumbsup:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Matt« (1. August 2010, 13:58)
Sonntag, 1. August 2010, 15:32
For the HD5970 we only have one block that will fit the reference layout:
Its hard to tell if your card is compatible. I would highly recommend to remove the stock fan and compare your card with the photo.
