• 03.04.2026, 13:28
edboswell
Which block?
Samstag, 16. Juni 2007, 20:16
Hi do you sell a block to fit the 8600 gts? I noticed you have one to fit the 8600 gt, but I wasn't sure if it meant the gts aswell...
Thanks
Ed
Napalm
Re: Which block?
Sonntag, 17. Juni 2007, 17:28
the support told me that some members have successfully mounted an 8600gt cooler on a gts.since my topic in the german forum was pretty much ignored i cannot tell you if it works.the big mystery is if those successfully mounted coolers have been put on cards with the referece design or a custom layout by some manufacturer.
