• 03.01.2026, 11:17
MrToad
Suggestion: Support for Dallas SC/MAXIM DS18S20/DS18B20 digital temp probes
Dienstag, 7. Dezember 2010, 16:28
Any plans to add support for these?
Using the all-too-common 10k NTC resistor based probes might be an inexpensive way to measure temperature, but you do get rather unreliable results... I'd say +- 3C is about as accurate as they get.
I don't think dropping support for "analog" probes is a good idea, but adding the option of using digital ones (maybe as an add-on board?) would be great...
Weihnachts-Shoggy
Dienstag, 7. Dezember 2010, 18:30
The aquaero can not be modified to use sensors like that.
MrToad
Mittwoch, 8. Dezember 2010, 11:32
That's a shame... It would be the icing on the cake :) Maybe one day we'll have an "Aquatemp" module, who knows ;)
