• 15.04.2026, 15:38
KoMM
570/580 waterblock
Sonntag, 9. Januar 2011, 23:52
Hello, are you planning to release a nickel block for the 570/580 gtx ?
Thanks
Montag, 10. Januar 2011, 12:04
Should be available in the future but currently we have so many orders that it is hard enough to keep up with the demand of the regular copper version. We can start the nickel plated variants when we have enough copper blocks in stock.
KoMM
Montag, 10. Januar 2011, 21:21
Hmm do you think its gonna be available in 1-2 months? Nickel is super sexy but i cant wait that long :(
On the currect 580 block can i fit 2 straight compression fittings or do i need 45° ones?
Dienstag, 11. Januar 2011, 08:39
I hope they will be available much earlier.
You can also use straight connectors. There is no reason why you would need 45° connectors.
KoMM
Dienstag, 11. Januar 2011, 13:58
I hope so too :)
Sexiest block around :P
