• 12.04.2026, 17:34
edboswell
aquabox 3 1/2" - black
Mittwoch, 27. Juni 2007, 15:41
Hi do you have the aquabox 3 1/2" in black?? If not...will it be made ;D
Thanks
Ed
edit: and what does:
Abstandshalter zur Montage von airplex PRO/XT (Set 4 Stück mit Schrauben)
...mean in english?
Nitrix
Re: aquabox 3 1/2" - black
Mittwoch, 27. Juni 2007, 15:44
if you can get about 20-30 like minded people im sure its possible
gr3if
Donnerstag, 28. Juni 2007, 00:54
ger-- Eng:
Spacer to use the Radiator passiv
So there are Screws included and some Spacers to fill the gap of the missing fans
