• 27.03.2026, 16:41
bla2222
Clicking noises from aquaero flow sensor.
Mittwoch, 20. Juli 2011, 14:53
Hi! I just put together my new water loop, just testing the pump etc. I notice that there is a distinct, and quite loud, clicking sound from the new Aquacomputer High Flow sensor. Now, I've tried to change the orientation, but there is no difference. I also though that this sensor is bi-directional, and I haven't changed the direction of flow. The loop should be bled as far as I can tell.
Now, I see that some people posting on various forums do have this problem, but is this a manufacturing fault or is there something I can do to get rid of the problem?
PGPT
Donnerstag, 21. Juli 2011, 22:03
-I had similar problem, tried and best position is with stainless faceplate upwards (as in attached picture).
»PGPT« hat folgendes Bild angehängt:
:thumbsup: i7 2600K EK Supreme HF - GTX570 aquagraFX - 4x2Gb Kingston HyperX 1600 - Asus P8P67 DLuxe - Corsair AX1200 - Corsair Obsidian 800D - Aquastream XT Ultra - 3x120+1x140 rads - Aquaero 5 XT (fw 1030) Win7 Ultimate 64 :thumbsup:
