Sie sind nicht angemeldet.
gahlaktus
aioneru
Phatboy's solution worked for me!!!
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »aioneru« (29. Mai 2011, 12:37)
gahlaktus
I didn't check the numbers but 2 updates for .NET 4 were listed in the built-in windows update immediately after installation. I've checked my update history and they are as follows:Did you install those two updates for .NET 4 ? Were they detected via standard built-in Windows Update or did you get them via MS Windows Update webiste ? What nuber exactly did they have because the second one is actually for .NET 3 and can't be installed since it's alread contained in standard Windows 7 install ?
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »gahlaktus« (29. Mai 2011, 21:54)
aioneru
That was way too crazy. I took the system with me into the office today and the big surprise: the aquasuite was working
Of course I can't tell if that will also solve the problems on other PCs.
Phatboy69
Don't ask...That was way too crazy. I took the system with me into the office today and the big surprise: the aquasuite was working
The only idea we had it could be something with other USB devices because that was the only thing that has been changed. Back at home I was able to confirm that. My monitor has a USB interface for remote control. When it is connected I can not start the aquasuite; when unplugged everything is fine. Well, so tomorrow I also have to carry the monitor with me. Likely that this problem could also happen with other USB devices. We already have an idea so the solution is nearOf course I can't tell if that will also solve the problems on other PCs.
Together with a customer we were also able to fix another problem which prevents the aquasuite to run. Besides that a few other things have been fixed.
So far it looks good that we will have a Beta 3 available tomorrow.
I am Intel of Borg. Resistance is futile. You will be assimilated.
