• 19.12.2025, 03:45
elbeasto
Kryos CPU Blocks - updated spacing spec.
vendredi 3 juin 2011, 07:02
At what point did ALL Kryos blocks have the update spacing between the inlet/outlet holes?
Is it still possible to buy one without the greater distance between holes?
I'm wanting to buy one but need to make sure it has the greater spacing because I'm using 1/2"-3/4" BP compression fittings.
Thanks. :)
error126
vendredi 10 juin 2011, 00:27
The Delrin ones still have the old spacing.
