• 22.03.2026, 15:49
jamel
Searching software sensor interface/data format documentation.
Mittwoch, 30. Mai 2012, 17:24
First of all, good morning to all.
I was wondering if there is a documentation available (in English) on the interface - and data formats - used to provide software sensor data that can be imported into aquasuite?
In other words, I would like to know how I can generate my own counters from my applications so I can capture and use them to setup controls in my aquacomputer.
I believe that AIDA is one application using such mechanism to export counters via shared memory. I would like to do the same, but from my own application.
I am programming in C/Win32.
Thank you in advance for your help and directions.
Best regards,
-Jamel
Mittwoch, 30. Mai 2012, 22:11
Hello,
a sdk is not available at this moment.
Sebastian
jamel
Samstag, 2. Juni 2012, 04:16
Hi Sebastian,
Thank you for your answer. I am looking forward using your SDK when it will be released.
Best regards,
-Jamel
