Sie sind nicht angemeldet.
BorisTheSpider
cc01
I was going to use the LED output with a RGB LED, making it possible to switch colour as the temperature changes. Not sure if the PWM outputs would be able to display the temperature changes? Is this selectable in Aquasuite 2012?Never tried on the aquaero and not sure what output it can provide but if you do try, they need to be parallel - in series they will be dim.
If you can't use the RGB output, you could put single colour LEDs on the PWM outputs (the 2 pin ones) - I'm not sure of the current rating though, so you'd have to check that, but they work fine for the single ultra-bright UV LED I have in my res.
Ok, thanks for the link. Off to read that thread now. Will post more info here when I've gotten wiser.This thread RGB LED suggests that you can only use one RGB LED on the Aquaero.
BorisTheSpider
"I was going to use the LED output with a RGB LED, making it possible to switch colour as the temperature changes. Not sure if the PWM outputs would be able to display the temperature changes? Is this selectable in Aquasuite 2012?"
3 mm.? Doesn't say so anywhere in all descriptions I've seen of the Aqualis reservoirs. I assumed it would be 5 mm.?I see you are stuck between "Design" and actual.
The unit is designed for only ONE RGB LED output and that is all any employee will tell you, it is the only thing he can tell you. My son has a Tee Shirt that he wears, it says: "I void Warranties"
I have the RGB Led in the back center position of my Aquatube Res. So that it is directly facing the view window.
I use it for the nightlight in the office. I can see the water waves on the opposite wall with the lights out.
I think useing the Aquabus 4 pin Y cable will work just fine, and then fill the other four spots on the Res with solid color ones driven by the PWM outputs of the AQ5. Set up a controller related to temperature and the PWM output. Done.
Be aware that the AC RGB LED is a 5mm diameter, and most other LED holes are 3mm to fit single color LEDs.
