• 22.03.2026, 21:20
guy59
windows 8
Freitag, 9. November 2012, 09:03
I just installed windows 8 and AquaSuite dont really works.
In any case, it is unusable.
Freitag, 9. November 2012, 09:48
A new version should be available within the next days which is also optimized for Windows 8.
Which problem do you have? Normally it should already work since we and other customers are able to us it.
guy59
Freitag, 9. November 2012, 11:07
Thank's you for answer,
bern43
Montag, 12. November 2012, 14:45
Any estimate for the Windows 8 optimized version? Just loaded up Windows 8 last night and will hold off on installing if the new beta is coming soon.
Dienstag, 13. November 2012, 12:18
I can not tell an exact date. Should be available in the next few days.
