• 14.12.2025, 02:35
CasualCat2001
data log questions
dimanche 26 janvier 2014, 16:19
I have some questions about the Data log sections of Aquasuite 2014 1.3.
1: what do the three buttons below actually do?
2. Does anyone know more about these 2 pages? I was able to get an xml file created but it appears to have a single entry as opposed to multiple temperatures over time. The xml I have too doesn't appear to be automatic. I think I actually created it initially with the button in the above picture, but again it doesn't appear to be updating.
3. Does anyone know what all the various buttons/settings are for the page below as well as why I can't get it to show backwards in time even though the computer and aquasuite were running during the time in which no data is plotted on the graph?
4. Similar to above how can I show a longer time frame in this graph?
ETA: I think ultimately what I'm trying to do is capture some of this data to a file I can view later if I wish. For example were I to have an issue with my computer I'd be able to view a file and look back in time to make sure I didn't have any temperature spikes or any other data points of note should I wish to track them. Is this something that can be done and how?
Thanks!
Ce message a été modifié 3 fois. Dernière modification effectuée par "CasualCat2001" (26 janvier 2014, 16:25)
dimanche 26 janvier 2014, 18:31
CasualCat2001
dimanche 26 janvier 2014, 22:14
Thank you for that Sebastian.
Am I correct that this file: aquasuite_db.database located in C:\ProgramData\aquasuite-data is tied to the data logging? Is there a way (or could it be a future feature) to move this database, since it seems to involve a lot of writes, to a different hdd and/or location of our choice? Thanks.
Ce message a été modifié 1 fois. Dernière modification effectuée par "CasualCat2001" (26 janvier 2014, 22:21)
bmxer4l1fe
dimanche 26 janvier 2014, 22:40
I have a Different issue, but your pictures will help nicely. Any time i make a chart and put it on an ovierview page, the time on the x axis of the chart goes back to 1973. How do i define the length of the X axis?
