• 31.01.2026, 12:09
kshafe777
Sonntag, 6. April 2014, 00:59
the monsoon site shows same specs as the phobya... unless i am reading them completely wrong, which i very well could be.. 8|
~Kevin~
Phanteks Enthoo Asus Crosshair V Formula Z AMD Vishera 8350 ASUS GTX 780Ti DCUIIOC 32 GB G.Skill 2133 9L RAM Corsair ax860i
EK Supremacy CPU Block EK FC Asus GTX 780Ti DCII Full block ( on the way :) ) EK D5 pump EK x3 150 res
420 Alphacool rad - 30mm 280 Alphacool rad - 60mm 280 Alphacool rad - 45mm Noctua NF-A14 PWM's Aquaero 6XT
mandrix
Sonntag, 6. April 2014, 01:16
The Phobya is a "flow through" type and the Monsoon is a plug type.
kshafe777
Sonntag, 6. April 2014, 03:28
Oh ... Yeah... Monsoon has an adapter, 45 or 90 degrees and you put the sensor on the back side of it.
~Kevin~
