• 03.04.2026, 06:08
miix
Automatic temerature control sensor
Samstag, 11. Oktober 2014, 14:57
I was wondering if it is possible to change the sensor that the "Automatic temerature control" option from the poweradjust 3 Ultra uses.
I did a lot of reading before I baught this, but now I cannot find the option to change it to other sensors, like CPU temp from OpenHardwareMonitor.
Anyone having the same problem, or is this how it works? If it cannot be changed, its just a waste for me...
Samstag, 11. Oktober 2014, 20:39
This options only available with a aquaero 5/6. The poweradjust can only use the connected sensor.
miix
Sonntag, 12. Oktober 2014, 14:34
Love missinformation. Can the Aqaero run 6 GT AP-15's and 2 DDC pumps?
Montag, 13. Oktober 2014, 09:55
An aquaero 6 without any problems. An aquaero 5 only when water cooled or at least it is highly recommend to do so.
