• 11.03.2026, 15:34
pegleg
Usb Flow Sensor
Thursday, October 30th 2014, 12:06pm
I just updated to the newer aquasuite software and now my usb flow sensor is not working .anybody have any ideas
Monday, November 3rd 2014, 8:56am
I gave you three older versions of the aquasuite. Anything new here?
Jakusonfire
Tuesday, November 4th 2014, 7:56am
This sort of thing has happened to me before plenty of times but it always fixed itself just by removing all power from the Aquaero, disconnecting the sensor, repowering aquaero, depowering aquaero, reconnecting sensor, repower aquaero. Along with just several system restarts.
pegleg
Monday, November 17th 2014, 3:00am
yea, i tried everything, this is the second one that i bought.It will be there, then just not there.don't understand. when i uninstall the software then install its ok then shut down computer it wont be there and i have it hooked up both ways to the usb port on motherboard and hooked to the aquaero 5 xt does the aquaero 6 have 2 high flow ports thinking about buying that one ..lol when i uninstall the software i always get this
pegleg has attached the following image:
This post has been edited 1 times, last edit by "pegleg" (Nov 17th 2014, 3:09am)
Monday, November 17th 2014, 11:06am
The uninstall routine in the current aquasuite version is faulty. Its is already fixed for the next release.
pegleg
Tuesday, November 18th 2014, 9:51am
ok,on the uninstall but why do i keep getting this about my flow meter. it is hooked to the usb on the motherboard
Tuesday, November 18th 2014, 11:22am
Well, then it seems you have hardware defect.
pegleg
Wednesday, November 19th 2014, 3:43am
ok so now what do i do
Wednesday, November 19th 2014, 11:12am
Send it in for a check.
pegleg
Friday, November 21st 2014, 7:04am
well i just got done installing the new aquaero 6 xt love it. but my flow sensor it still doing the same thing .u cant send a replacement?
on the aq6 when i set the pumps to preset 100% getting all the bubble out..lol and then went and clicked disable device keys my pumps went to 40% where i had it set before why did it do this when i just clicked disable device keys
ok, pulled the flow sensor out where do i need to send it?
This post has been edited 2 times, last edit by "pegleg" (Nov 24th 2014, 10:47am)
pegleg
Sunday, November 30th 2014, 5:16pm
they want 60 bucks to ship it back , i can just bye another one for that price,but i just got this about six to 8 month ago.
Chizzy
Friday, December 5th 2014, 4:12am
Wow, I have the same problem. Well, I guess that tells me where I stand. That really sucks.
