AGAIN: Yes it is known that it does not work. That is, any D5 PWM pump of any brand, with aquaero 5 or 6 though fan channel in PWM mode. It does not work.
Only D5 pump you can properly control is Aqua Computer D5 pump motor with USB and aquabus interface which connects to aquaero via aquabus.
You can also control D5-Vario, but it will work between 3000 and 4800 rpm aprox. So limited range.
The D5 pwm pumps most certainly work just fine with the Aquaero 5 units. I have 2 Aquaero 5 Pro's and 2 D5 pwm pumps working fine via pwm.
