Sie sind nicht angemeldet.
Bytales
I placed my order on the 19th of February and my order still hasn't shipped or anything. it still just says, "processing order"... Is this normal? whats the deal?
and waiting !
and waiting
and waiting
Jsep87
Welcome to the club, i ordered stuff in november 2014, and i still need to receive a double circuit radiator from that order, supposedly it should arrive this week, but still havent received anything yet.
Another order that i placed on 8th of february shipped, but the radiators from that order are going to come sometime in the first 2 weeks of april
So if you have radiators, i think we need to wait.
The best bet would have been to buy the radiators from a third party who has them in stock, but the 140.2 double circuit copper blades radiator, i believe no one has such an exotic radiator in stock, so i ha to order from them directly.
Still waiting !and waiting !
and waiting
and waiting
and waiting
.... ummmm and a few other odds and ends. I held off on the reservoir, tubing, and connectors... planning on going to 3rd party for those.
Jsep87
Any advice on my order? This is what I've got so far. Lol and not sure how much more I can afford at this rate ! >8 )
The new aquaero 6 is an improved version of the aquaero 5. Our main target was a dramatic increase of the available power on the outputs. Other than the aquaero 5 which works with an analog voltage control, this time we used very efficient switching controllers of the latest generation. The performance capability of the aquaero 5 is mainly limited by the temperature of the voltage regulators since they become pretty hot when you attach some stuff and use it with lower voltages. The aquaero 6 has no problems in this area and the maximum power is only limited by the current which means you can go to the limits without worrying about the temperatures.
Bytales
Bytales
Anyways, temps will be better.
Are you sure? The water loop will run hotter than the ambient air.
SO it really makes no sense in watercooling Aquaero 6 XT, doesnt it ?
The maximum current per channel is 2,5A (30W at 12V) without any special cooling. The aquaero 6 does not even have a passive heatsink! Anyway, we will also offer a waterblock for the aquaero 6 since it will allow to go a bit further with a maximum of 3A (36W at 12V).
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (1. März 2015, 20:46)
