• 29.01.2026, 02:45
m0rg@live.co.uk
Damaged Capacitor
Friday, March 6th 2015, 10:28am
Hi there i have accidentally damaged a capacitor on my aquaero 5 LT marked as "22 CFK M13"
does anyone know where i can get a replacement in the UK, the contact points are undamaged so it should be just a case of soldering a new one in :)
Railgun
Friday, March 6th 2015, 11:43am
Mouser or Farnell are your best bets, but without knowing the rating...
m0rg@live.co.uk
Friday, March 6th 2015, 1:13pm
http://industrial.panasonic.com/lecs/www…BA0000CE120.pdf
looking at the code and assuming its a Panasonic cap C should be the voltage 16v FK would be the series of the capacitor 22 would be uF
that leaves two sizes in the range B 4.6mm and C 5.9mm
EEEFK1C220UR or EEEFK1C220R
am i assuming that this is what i need working of an assumption . ?(
http://uk.rs-online.com/web/p/aluminium-capacitors/5370449/
Railgun
Friday, March 6th 2015, 4:15pm
That looks about right, but I can't say one way or another. I will say that soldering surface mount caps in this regard is not the easiest thing ever. But...I don't have the best tools nor steadiest hands anymore.
Similar threads
