• 15.04.2026, 05:14
JayCub
NZXT
mercredi 22 avril 2015, 22:59
Hi guys could some-one kindly point out the orientation of the usb cable, when attatching to the nzxt expansion hub or to a guide if it is already on here some where
thank you in advance
Tom :D
Railgun
mercredi 22 avril 2015, 23:10
With the input facing down, all the grounds are to the left.
JayCub
Brilliant
jeudi 23 avril 2015, 11:30
Thank you very much for the diagram, really helpful and I can save the image, this should be a sticky to be honest
Cheers Railgun appreciated
Tom
also can be found on page 6 of the aquero manual, section 3.9
Ce message a été modifié 1 fois. Dernière modification effectuée par "JayCub" (24 avril 2015, 20:54)
