• 24.12.2025, 06:30
Kaffefilter5
Software Sensors in AquaSuite
Sunday, May 3rd 2015, 1:00am
So the other day I upgraded windows 8 to 8.1, and installed aquasuite. Everything went perfectly smoothly, except for that nothing shows up when I select data source on any of the software temp sensors. I have tried installing AIDA64, HWiNFO and Open HW Monitor + reinstalling one more time, but nothing appears still. BTW, the temps show up in OpenHWMonitor, so it is not like my MoBo doesnt let software read temps. I have also both reset and firmware updated my aquaero 5 LT, but nothing really happens. I start it as administrator too, so that should not be any problem. Everything else on the aquaero works perfectly though, so i have no idea what it is.
Thank You in advance
Sunday, May 3rd 2015, 1:37am
Have you setup both AIADA64 and aquasuite for WMI/windows services?
Here is a thread where I outline the steps necessary to pass information from AIDA64 to aquasuite.
Jakusonfire
Monday, May 4th 2015, 7:55am
If open hardware monitor is reading values it should work just fine. It doesn't need to be configured like AIDA
It sounds like the Aqua computer windows service. Try un-installing and reinstalling it from the Aquasuite settings tab
This post has been edited 1 times, last edit by "Jakusonfire" (May 4th 2015, 7:56am)
Monday, May 4th 2015, 7:50pm
Indeed, though I believe "Shared Memory Support" is required, so be sure it remains active.
