• 02.04.2026, 23:05
JasonMorris
My Aquaero 6 Pro shows the wrong time
Montag, 30. November 2015, 22:17
The time on my pc is correct and in the Aquasuite software it's fine (see attachment) but the display on the unit is always an hour ahead. Firmware is v2400 and Aquasuite v2015 release 9. Running under Windows 7 64bit. Unit is connected via USB only.
Any ideas?
thanks.
»JasonMorris« hat folgende Datei angehängt:
  • Aquaero 6.jpg (22,92 kB - 148 mal heruntergeladen - zuletzt: Heute, 17:54)
Dienstag, 1. Dezember 2015, 11:55
Make sure that your Windows configuration is using the correct time zone. The correct time alone will not be enough because the time zone also plays an important role here.
JasonMorris
Sonntag, 6. Dezember 2015, 10:46
The Windows timezone is correct (London) so what should the timezone be on the Aquaero 6 please Shoggy?
thanks
Sonntag, 6. Dezember 2015, 12:12
you have to set the timezone in the aquaero to your local settings -> London == 0, in your setup i see "+1" (Berlin)
JasonMorris
Sonntag, 6. Dezember 2015, 19:47
Perfect Shoggy. Many thanks :)
