You are not logged in.
X584EVA
This post has been edited 1 times, last edit by "X584EVA" (Feb 17th 2016, 7:37pm)
X584EVA
Ya can never be too careful these days!We will cancel it anyway when we see that you placed two orders but only one is paid.
By the way: how should you be charged for the first order? If you send no money we will never get money - it is just that easy![]()
This post has been edited 6 times, last edit by "X584EVA" (Feb 18th 2016, 7:03pm)
X584EVA
^ Bump for staff attention!
^This post has been edited 2 times, last edit by "X584EVA" (Feb 19th 2016, 10:03pm)
Edit - Nevermind, I decided to scrap the Dual loop Aquastream XT idea and instead have opted for a single DDC Plus, which I will stick my old Swiftech top on.
I do have one last question though if anyone can answer! - So I've bought the " Laing DDC 1T Plus" from the Aqua Store, together with the connector kit for the Aquaero 6. Is this pump PWM or regular DC controlled?
which indicates to me that the pump is voltage controlled.
Quoted
By voltage variation the DDC DC pump can easily be adjusted over a wide power range
