• 31.12.2025, 00:45
Blade Runner
Aquastream XT Ultimate Fitting Question
Montag, 4. April 2016, 20:31
Just had my new XT Ultimate delivered for a new build I am doing and I just had a thought.
Is there any reason why the pump cant be mounted and run, on its side like in the attached picture?
It would just give me a few more mounting options.
Thanks in advance if anyone can help.
ETA. Just had another thought! They are coming thick and fast tonight!.
Could the red end part with all the electronics inside, be mounted remotely from the pump body it I extended the wires?
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Blade Runner« (4. April 2016, 22:06)
Montag, 4. April 2016, 22:37
You can run it like that. My aquastream XT also runs on the side since several years now.
It is possible to place the rear cover somewhere else.
Blade Runner
Montag, 4. April 2016, 22:49
Thanks Shoggy, that is great news :-)
