• 10.04.2026, 22:57
Freitag, 27. Oktober 2017, 14:26
A small enhancement request for aquasuite navigation.
Currently it is possible to order the overview pages under the Overview Pages tab.
Being somewhat anal, I would also like to be able to move the Main Tabs themselves up/down to group pumps, etc.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »InfoSeeker« (27. Oktober 2017, 14:29)
Fieldrider
Freitag, 27. Oktober 2017, 15:06
This idea came up a while ago in a german thread, as far as I remember it has been put on the list for upcoming features but with low priority.
Sonntag, 29. Oktober 2017, 02:32
Some time back aquasuite was made able to use extended character.
The current version appears to have lost that ability... on restart.
The character remains as long as aquasuite is running, but returns a "?" on restart.
Mittwoch, 1. November 2017, 07:15
The aquasuite can handle UTF8 but the device has an limited character set.
The names for sensors are stored in the device.
Mittwoch, 1. November 2017, 14:59
Understood.
Mittwoch, 1. November 2017, 15:46
Are there some max display size issues with aquasuite?
After a bit of blind navigation, I was finally able to position an object on my desktop (DT.jpg)
When I open the display page to edit it, the object is in a different location (AQS.jpg)
But when I close the edit page, the object still shows in the correct location.
Maybe the "edit on desktop display" has a limited pixel width and it rewinds from the left side for items in excess of this limit?
The monitor is a 5k monitor (DPS.jpg)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (2. November 2017, 12:43)
