• 10.01.2026, 05:20
XAML help requested
samedi 28 juillet 2018, 21:18
I am trying to display some text rotated 90 degrees, but not knowing XAML, my attempts have failed so far.
I am hoping one of the clever folks on this forum can provide direction.
From Googling, I believe I need to insert code similar to this:
<TextBlock>
<TextBlock.RenderTransform>
<RotateTransform Angle="90"/>
</TextBlock.RenderTransform>
</TextBlock>
But I have not been able to get the code syntax/placement correctly.
My current code is a slightly modified preset from the aquasuite:
<UserControl
x:Name="this"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:sys="clr-namespace:System;assembly=mscorlib"
mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="300">
<Grid>
<TextBlock
Text="Workload vs. Coolant Temp"
Opacity="1.0"
Height="Auto"
Width="Auto"
Foreground="#ffffffff"
FontSize="15"
FontFamily="Segoe UI"
FontWeight="Normal"
Margin="0,0,0,0"
Padding="0,0,0,0"
HorizontalAlignment="Center"
VerticalAlignment="bottom"/>
</Grid>
</UserControl>
mardi 31 juillet 2018, 10:20
Code source
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
<UserControl
x:Name="this"
<Grid>
<TextBlock
Opacity="1.0"
Height="Auto"
Width="Auto"
Foreground="Black"
FontSize="15"
FontWeight="Normal"
Margin="0,0,0,0"
VerticalAlignment="Top">
</TextBlock>
</Grid>
</UserControl>
You can also use an online xaml editor for build an layout:
http://yuvaltz.github.io/granularpad/
mardi 31 juillet 2018, 21:27
Thank you very much.
Now I just have to repair my system which cratered on my Sunday. *sigh*
Discussions similaires
