• 24.01.2026, 23:00
Kayvan
Extension cable for Aquaero 6 display?
Monday, September 3rd 2018, 11:02pm
I've been looking for a 24 pin 0.5mm pitch ribbon cable with headers to connect the display to the main board of the Aquaero.
I have searched google for days and can not find anything even close. All the cables I have found are 1mm pitch.
Even individual jumper cables are 1mm.
Does anybody know where to get this?
I am trying to place the display in a different location than the main unit.
Tuesday, September 4th 2018, 1:58am
What length of cable are you looking for?
The Gigant series external radiators have the display mounted separate from the aquaero with a cable about 20 cm long.
If 20 cm is sufficient, it should be a stock item you can purchase from aquacomputer.
If you need longer, you may be able to negotiate a custom order (if length is not limited).
support@aqua-computer.de
This post has been edited 1 times, last edit by "InfoSeeker" (Sep 4th 2018, 2:00am)
Kayvan
Tuesday, September 11th 2018, 4:02pm
Thanks! Just ordered one via email address provided.
Citroene
Saturday, February 6th 2021, 10:03pm
Is it possible to buy the extension cable?
because i send an email 1 week ago and didn't get an answer
Sunday, February 7th 2021, 1:19am
Look here:
Quoted
Please note:
Due to a high volume of inquiries, it currently takes up to two weeks to respond to e-mails.
Sunday, February 7th 2021, 1:23am
Since the gigant radiators are still listed in aquacomputer's webshop, I believe you can still purchase the cable.
But on their support page they have the following statement:
Quoted
Please note:
Edit: lol, ninja'd
This post has been edited 3 times, last edit by "InfoSeeker" (Feb 7th 2021, 1:26am)
