• 22.02.2026, 06:18
realmmoto
Filter fitting Size?
Mittwoch, 13. Mai 2020, 22:51
Need help to find out what type & size of thread is on these fittings. I have had this filter with stainless steel mesh, ball valves. The new version is stander with the G1/4 thread—the one I have not sure. I have never used it because of that. Is there a cross over for G 1/4?
https://drive.google.com/open?id=10yWvI6…TDonBWxHHK3dOvb
»realmmoto« hat folgende Dateien angehängt:
  • AC_Filter 6.jpg (28,01 kB - 107 mal heruntergeladen - zuletzt: 17. Februar 2026, 12:47)
  • AC_Filter 7.jpg (53,32 kB - 99 mal heruntergeladen - zuletzt: 24. Januar 2026, 20:32)
  • AC_Filter 8.jpg (57,67 kB - 103 mal heruntergeladen - zuletzt: 19. Februar 2026, 06:58)
  • AC_Filter 9.jpg (29,06 kB - 112 mal heruntergeladen - zuletzt: 7. Februar 2026, 19:05)
Dieser Beitrag wurde bereits 6 mal editiert, zuletzt von »realmmoto« (15. Mai 2020, 17:16)
realmmoto
Dienstag, 19. Mai 2020, 19:55
I just wanted to pass this info forward to anyone that may have this same question as I did. I did reached out to AquaComputer support as well to see if they had an idea what I needed. They did reply, and also provide a solution for me thank you and appreciate the support. :)
Here is there reply:
Hello Antonio,
this seems to be an early variant that used G1/8 fittings.
The thread of G1/8 fitting has a diameter of about 9.6mm while for G1/4 it is about 12.9mm.
You could get G1/8 fittings to match your tubing size or you have to use a G1/8 to G1/4 adapter.
kind regards
Sven Hanisch
Sven Hanisch
Vertrieb/Sales
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Germany
