• 10.01.2026, 13:28
ND1
ULTITUBE D5 150 PRO with D5 Next pump - glass is broken, scratch, glue?
Montag, 23. November 2020, 20:39
Hello. Just received my Ultitube 150 with D5 Next and noticed something. Please take a look on atachments. Scratch (?) is only on the outer side of res.
»ND1« hat folgende Dateien angehängt:
  • 11.jpg (240,88 kB - 287 mal heruntergeladen - zuletzt: Heute, 05:33)
  • 22.jpg (210,82 kB - 273 mal heruntergeladen - zuletzt: 8. Januar 2026, 20:52)
Dienstag, 24. November 2020, 17:06
Really hard to see what kind of damage this could be by the picture.
Can you take other pictures? The glass is 5mm thick so it will not break by a scratch but this shouldn't happen.
ND1
Mittwoch, 25. November 2020, 13:23
Added additional photos...
  • 33.jpg (136,26 kB - 266 mal heruntergeladen - zuletzt: 4. Dezember 2025, 00:51)
  • 44.jpg (142,25 kB - 269 mal heruntergeladen - zuletzt: 30. Dezember 2025, 05:03)
  • 55.jpg (183,41 kB - 291 mal heruntergeladen - zuletzt: 22. November 2025, 11:01)
Mittwoch, 25. November 2020, 14:51
It's no scratch. This is a little bit of glue that has flown too deep. You can contact the support team or remove it careful using a sharp knife.
ND1
Montag, 30. November 2020, 15:31
Yes, it's a new item.
Thanks for the explanation!
