• 31.03.2026, 06:28
lion44
Sensor Compatibility
dimanche 6 juin 2021, 21:04
Does this temperature sensor work with the Octo?
https://shop.aquacomputer.de/product_inf…roducts_id=3126
dimanche 6 juin 2021, 22:36
Yes... the product page need to be updated to add the OCTO to the compatibility list.
Edit: the sensor you referenced is listed in the OCTO manual:
5.7. Connector for temperature sensors
Connector for up to four temperature sensors.
Compatible sensors:
  • Temperature sensor inline G1/4 (53066)
  • Temperature sensor inner/outer thread G1/4 (53067)
  • Temperature sensor G1/4 (53147)
  • Temperature sensor plug&cool (53025)
  • Temperature sensor 70 cm (53026)
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (6 juin 2021, 22:57)
lion44
lundi 7 juin 2021, 06:24
Compatible sensors:
Thank you! :D
