• 29.01.2026, 23:49
WinstonWoof
Display Aquasuite on Specific Monitor
Sonntag, 18. Juli 2021, 18:11
Is it possible to set Aquasuite to display on a specific monitor ?
Had a good look but can't seem to find anything that will do it
Sonntag, 18. Juli 2021, 20:23
Yes, but you don't assign a monitor.
Aquasuite considers all monitors as a single canvas. e.g. if you have 2 monitors side by side, both being 2000x1000 pixels, the canvas would be 4000 x 1000 pixels.
To place an object on the 'second' monitor, 10 pixels from the left edge, and10 pixels from the top you would specify the x/y as 2010/10. (settings.jpg)
If the monitors were one above the other, the canvas would be 2000x2000 pixels.
I am not sure how it works with 2 monitors side by side, with the right monitor designated as the primary (left monitor is #2), but you may need to use negative x in that case. Same if 2 monitors are vertically mounted and the 2nd monitor is the top monitor.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (18. Juli 2021, 20:24)
WinstonWoof
Sonntag, 18. Juli 2021, 23:07
To place an object on the 'second' monitor, 10 pixels from the left edge, and10 pixels from the top you would specify the x/y as 2010/10. ([attach]8525[/attach])
where the flip is that particular settings page?
DaLiu
Montag, 19. Juli 2021, 02:33
It will be great if they will implemate an option to decide on which monitor you want to display the sensors.
Montag, 19. Juli 2021, 05:15
  • select the overview page you want to work on
  • unlock the page to edit it
  • right-click on the object you want to move
  • select 'Settings' from the pop-up menu
Grestorn
Montag, 19. Juli 2021, 21:10
The way they did it might be a bit unintuitive, but it has the advantage that the display can span across multiple monitors.
WinstonWoof
Donnerstag, 22. Juli 2021, 23:05
  • [attach]8526[/attach]
So you have to move each element individually ?
What a faff!!
Freitag, 23. Juli 2021, 01:20
What a faff!!
It is possible to select any or all objects on a Overview page (select.jpg)
Then Drag & Drop to a new position (drag_drop.jpg)
But the resolution of your drop is limited to the steadiness of your hand, which may be improved by having the grid-lock turned on.
The optimum would be to select multiple objects and have the ability to offset all selected objects by a specific x/y, but that is currently not available.
Edit: link to a 10 SECOND CLIP showing a multi-object move.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (23. Juli 2021, 01:55)
WinstonWoof
Freitag, 23. Juli 2021, 07:41
What a faff!!
It is possible to select any or all objects on a Overview page ([attach]8560[/attach])
Then Drag & Drop to a new position ([attach]8561[/attach])
Which brings to mind 2 further improvements that could be made.
1) Enable CTRL+A to select All
2) Enable Scaling of window to better facilitate placing of widgets anywhere on the available canvas
WinstonWoof
Freitag, 23. Juli 2021, 07:47
Of course I could always resize the AS window and stretch it over both monitors then drag & drop ;o)
Only PITA still then is lack of CTRL+A functionality
»WinstonWoof« hat folgende Datei angehängt:
  • Capture.JPG (443,23 kB - 163 mal heruntergeladen - zuletzt: 21. Januar 2026, 11:10)
WinstonWoof
Montag, 26. Juli 2021, 22:09
Damned annoying.
Since the update to X.41 I dont seem to be able to resize the Aquasuite window across multiple monitors :(
EDIT UPDATE
Closed & Reopened and worked as expected
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »WinstonWoof« (26. Juli 2021, 22:16)
