Sie sind nicht angemeldet.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (18. Juli 2021, 20:24)
WinstonWoof
where the flip is that particular settings page?Yes, but you don't assign a monitor.
Aquasuite considers all monitors as a single canvas. e.g. if you have 2 monitors side by side, both being 2000x1000 pixels, the canvas would be 4000 x 1000 pixels.
To place an object on the 'second' monitor, 10 pixels from the left edge, and10 pixels from the top you would specify the x/y as 2010/10. ([attach]8525[/attach])
If the monitors were one above the other, the canvas would be 2000x2000 pixels.
I am not sure how it works with 2 monitors side by side, with the right monitor designated as the primary (left monitor is #2), but you may need to use negative x in that case. Same if 2 monitors are vertically mounted and the 2nd monitor is the top monitor.
Grestorn
The way they did it might be a bit unintuitive, but it has the advantage that the display can span across multiple monitors.It will be great if they will implemate an option to decide on which monitor you want to display the sensors.
WinstonWoof
So you have to move each element individually ?where the flip is that particular settings page?
- select the overview page you want to work on
- unlock the page to edit it
- right-click on the object you want to move
- select 'Settings' from the pop-up menu
- [attach]8526[/attach]
What a faff!!
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (23. Juli 2021, 01:55)
WinstonWoof
Which brings to mind 2 further improvements that could be made.So you have to move each element individually ?
What a faff!!
It is possible to select any or all objects on a Overview page ([attach]8560[/attach])
Then Drag & Drop to a new position ([attach]8561[/attach])
But the resolution of your drop is limited to the steadiness of your hand, which may be improved by having the grid-lock turned on.
The optimum would be to select multiple objects and have the ability to offset all selected objects by a specific x/y, but that is currently not available.
Edit: link to a 10 SECOND CLIP showing a multi-object move.
