Sie sind nicht angemeldet.
pneuma
Montag, 9. August 2021, 06:03
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »pneuma« (9. August 2021, 06:07)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »etoel« (9. August 2021, 06:22)
pneuma
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »pneuma« (9. August 2021, 07:13)
pneuma
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »pneuma« (9. August 2021, 22:29)
Flop Ysh
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Flop Ysh« (12. August 2021, 14:11)
pneuma
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »pneuma« (14. August 2021, 21:05)
pneuma
pneuma
Looks fine to me. Filling should also work without any issues as your system looks tight to me.
At boot LEAKSHIELD can not get data about the rpm of your pump for flow. So it will use the values set for Standby and then switch to maximum pressure of your pump until it get values to calcualte the exactly adaptive pressure.
If you want to change this you can disable the adaptive pressure in the assistent and also set Standby values to the same value as your pump needs. In this case LEAKSHIELD will always use the same pressure.
About your question about pressure during fill mode: In this mode the vacuum will be 200 to 300mbar.
Please post the status log of LEAKSHIELD. Your vacuum pump has run too often which is indicating a leak. We need to check the details in the log.Looks fine to me. Filling should also work without any issues as your system looks tight to me.
I'm just having issues an alarm goes off maybe once an hour and I don't know why. It says it's due to the pumps but I have both of them at 40% which is far below the max of what they can be set to, which I believe is about 45-46% yet I still get this annoying alarm what should i set those settings to for the alarm?
https://drive.google.com/file/d/1nYJD_0j…iew?usp=sharing
ugokhan
I am having the same issue. I am about to go crazy. It says leak detected due to frequent pump activation. Pump pressure goes to 450 and then drops. If I set the pressure to 200 mb then it works fine.
Jacob
Freitag, 1. Oktober 2021, 11:18
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Jacob« (1. Oktober 2021, 19:13)
