• 28.03.2026, 00:09
Beun
Chipset bracket for cuplex pro?
dimanche 16 janvier 2005, 19:27
Is there a Chipset bracket for the cuplex pro?
I would like to fit a cuplex pro on my AMD processor and on the ASUS A8N SLI chipset :)
major23hh
Re: Chipset bracket for cuplex pro?
dimanche 16 janvier 2005, 19:58
hello,
no, there is no bracket for the cuplex pro, but I think I saw a unique solution in the "Selbstgebautes"-Forum.
You dont need a cuplex Pro for cooling the nVidia nForce 4 SLI Chipset, the Twinplex does its job good ;)
Beun
dimanche 16 janvier 2005, 19:59
Thanks, I would just like to attach two pro's :)
Do you know witch topic it was?
atomfrede
lundi 17 janvier 2005, 22:28
it was not the cuplex pro the user put onto the chipset, it was a normal cuplex.
he modded the plexiglas thing on it, so that he could use some screws put it on the chipset!
Beun
mardi 18 janvier 2005, 19:53
Okay that is a shame. I'm surprised AC doesn't make brackets for teh shipsets. I personally think they will sell even more cuplex pro that way :)
major23hh
mardi 18 janvier 2005, 23:30
no, i dont think so. another cuplex pro would decrease the cooling blocks flow to much and it wouldnt be profitable for the temperature. the twinplex is more than enough to cool down all avaiable chipsets :)
Puggy
jeudi 20 janvier 2005, 04:06
Citation de "0800-S-P-A-N-I"
Chipsets don't need very much cooling. When I tell people that I water cool mine (with a Twinplex for P4) they usually tell me that I'm wasting money and my flow, and that I would be better off with a passive heatsink instead. I happen to like water cooling everything, even my hard drives (with an Aquadrive on my 74gb Raptor).
Beun
jeudi 20 janvier 2005, 08:06
Okay thanx. I didn't know a cuplex pro influenced the flow more than a twin
