Sie sind nicht angemeldet.
KrzysztofGW
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »KrzysztofGW« (19. Dezember 2021, 23:22)
KrzysztofGW
On closer inspection, your screenshot seems to show the Virtual Sensor, you can see that you have a selection box for the sensor type, just take a Soft. Sensor and specify the high flow NEXT as data source.
KrzysztofGW
I cannot chose input for D5's control by flow. It is controlled by wired signal and I cannot adjust it.What happens if you choose "Flow" for the sensor instead of "Flow_signal", do you then get the Flow Next in the drop down box? Only reason I ask is that shows the same flow rate as indicated in your pic.
High flow 53068 shows output as high as 1500 lph (when it is like 100 lph). I do not see possibility to configure output. I can change the sensor type in input config of the pump. The chosen one shows the lowes values.You have to select High flow 53068, and in the sensor the same as output signal. Otherwise you get wrong values.
You have to configure the output signal in the flow sensor.
1. Configure you output Signal on your flow sensor
2. Configure the flow sensor input signal on your pump
