• 18.11.2025, 01:28
z00mantwo
Feature Request: Allow high flow NEXT "power" sensor to use alternate sensor source for temp like a temp sensor
Thursday, January 27th 2022, 6:34am
Allow high flow NEXT "power" sensor to use alternate sensor source for temp like a temp sensor connected to a OCTO. I already have a sensor on the OCTO attached to outside the case to get ambient temperature of the room the computer is in.
Thursday, January 27th 2022, 7:30am
This is not possible, this is only working with the external connected sennsor.
RE: Feature Request: Allow high flow NEXT "power" sensor to use alternate sensor source for temp like a temp sensor
Thursday, January 27th 2022, 1:10pm
If you are using a room ambient temperature sensor as the input to the High Flow NEXT's external sensor, your results will be astronomically wrong.
The external input should be a coolant sensor at the OUT port of the radiator, and the High Flow NEXT should be just head of the IN for the radiator.
This will give an estimate of the power dissipated by the radiator.
z00mantwo
Thursday, January 27th 2022, 1:58pm
Thanks. :) Figured that out after posting this. Miss interpreted "external sensor" as external to the case or room ambient.
I'll get a proper sensor ordered from aquacomputer.
z00mantwo
Friday, January 28th 2022, 8:33pm
What about when you have an OCTO and a high flow NEXT together and already have a water temp sensor connected to the OCTO? Can't move the sensor to the high flow NEXT since the plug sizes are different.
Saturday, January 29th 2022, 2:17am
Correct, currently THESE are your only options for the High Flow NEXT's 'external' temperature sensor port.
