• 08.11.2025, 10:37
z00mantwo
RGBpx way to emulate Razor "Spectrum Cycling" theme or the iQue "Gradient" theme?
mercredi 2 février 2022, 05:24
This would be similar to the "Color gradient" option, but rather than cycle the colors across the led strip the colors would cycle across the entire strip within the specified spectrum all as one.
Like in this video at 1:18
https://youtu.be/PBzVeo2bQBo
and you could specify the colors, how many steps and the speed of the cycling.
Maybe a checkbox in "Color gradient" that would say all LEDs at once or something like that.
Also shown in this video at 7:40
https://youtu.be/tkfengnRF9c
Actually "Color switch" with the fade option turned on is close but rather than sensor driven it would cycle at some user specified speed
Ce message a été modifié 4 fois. Dernière modification effectuée par "z00mantwo" (2 février 2022, 05:39)
Remayz
mercredi 2 février 2022, 12:36
the "Color change" preset?
you can select the colors, the speed, immediate change, fade or slide effect when going from one color to the other..
z00mantwo
mercredi 2 février 2022, 15:53
That is very close to what I'm looking for. Thanks.
Discussions similaires
