• 19.07.2025, 06:25
Top_Nurse
Inline filter mount question
Thursday, July 28th 2022, 6:43am
I posted the pic as the one I have isn't exactly the same as what is currently sold, but I would imagine the mount is the same (mine is a G 1/8 ). In the store, I noticed that they sell some mounts other than what comes with the filter. I removed one of the vertical Aquatubes in my Feeding Frenzy project and would like to get a mount that has roughly the same external dimensions as a standard Aquatube mount. Does anyone happen to know whether the 92mm size would work?
Jacob
RE: Inline filter mount question
Sunday, July 31st 2022, 11:50am
Quoted from "' work?[/quote"
The most suitable way is to choose the mounting bracket according to the size of the fan.
Or use hard tubes as a bracket for support. :)
https://shop.aquacomputer.de/product_inf…roducts_id=2529
This post has been edited 2 times, last edit by "Jacob" (Jul 31st 2022, 11:53am)
Top_Nurse
RE: RE: Inline filter mount question
Sunday, July 31st 2022, 10:37pm
Thanks Jacob for the idea of using a hard tube. I'll have to mull that over. :)
I'm kind of surprised that AC didn't make any aluminum mounting plates. ?(
This post has been edited 1 times, last edit by "Top_Nurse" (Jul 31st 2022, 10:52pm)
