Sie sind nicht angemeldet.
Even if the Aquasuite were software that you paid regular license fees to use, which it isn't, that wouldn't give you any right to third-party software and hardware support.I bought an aquasuite subscription and now I still need to buy Hwinfo (Well HWinfo can access power supplies for Aquasuite, so what you asked for is already there![]()
Taimer
I pay for my license every year.Even if the Aquasuite were software that you paid regular license fees to use, which it isn't, that wouldn't give you any right to third-party software and hardware support.I bought an aquasuite subscription and now I still need to buy Hwinfo (Well HWinfo can access power supplies for Aquasuite, so what you asked for is already there![]()
Where do you get such a thought?
You only have to pay for the HWINFO Pro version if you want to have shared memory support active 24/7. If you can deal with having to re-enable it after 12 hours, you can use the latest version for free. The other option is to use the last version that existed before the author decided to put a 12-hour limit on shared memory support. If you are OK with using a version prior to version 7.0 you can do so without limitation for free. The author of HWINFO only did this because many people were using the free version of the program in commercial applications. The details are explained HERE. The Personal Pro version of HWINFO costs $25 per year. If you auto-renew, it is only $12.50 per year. Whether its worth it is a personal decision. For me, the cost of AQS and HWINFO are miniscule compared to the cost of the hardware they control and monitor.I bought an aquasuite subscription and now I still need to buy Hwinfo (
