• 25.01.2026, 06:04
voidspace
Aquasuite not showing sensors
Montag, 4. September 2023, 22:32
Aquasuite is not showing any motherboard or video card sensors at all.
Can someone give me any idea why not. It is a proper pain in the bum
Thanks
»voidspace« hat folgende Datei angehängt:
  • no sensors.jpg (170,07 kB - 56 mal heruntergeladen - zuletzt: 20. Januar 2026, 20:28)
Remayz
Dienstag, 5. September 2023, 00:00
the monitoring is actually enabled on your end ?
Dienstag, 5. September 2023, 07:26
Shut down and power off your system, remove the power supply cable (high voltage).
Start your system and re assign the software sensors. .. x74 is the actual version.
voidspace
Freitag, 8. September 2023, 21:20
Looks like that was it, THX It was working ok before, did an update turn them off?
