Sie sind nicht angemeldet.
																		DeDog
																		DeDog
							Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »DeDog« (21. März 2024, 20:45)
																		Hufeisen
																		DeDog
 now use quality air cooling with liquid metal...but in oc the temperatures reach 105 °C (immediately stopped it)
 I didn't know it got so hot. I only found out now
																		Methodical
HI. thank you for the tip.![]()
I didn't realize that the fundamental piece of the system was missing![]()
I would like to push a latest series i9 but I don't know which pump to usenow use quality air cooling with liquid metal...but in oc the temperatures reach 105 °C (immediately stopped it)
-- In your opinion using two double circuit radiators, one 480 and one 360 and two d5 or better one aquastream ULTIMATE or 2 aquastream ULTIMATE...can I have the CPUs in oc below 85°C? ---![]()
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »Methodical« (5. April 2024, 13:01)
																		DeDog
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »DeDog« (25. März 2024, 21:33)
																		DeDog
Check out this video. The CPU was overheating and when he removed the CPU he found the CPU was missing a good amount of thermal paste. Have you checked that? Jayz2cents also have a video out there where he shows the MB was causing high CPU temps by overvolting the CPU. Something worth checking out before throwing money at the problem.
https://www.youtube.com/shorts/WZz9P3an_SU
In my opinion, there's probably something else going on with your setup causing the high temps that may need to be checked out. Are these normal or gaming temps?
I use 1 pump and a 420mm on the 7950x and the temps max at 90 during Cinebench stress test, but average temp is much lower. The temps average in the 60s during gaming and 40s-50s during regular use. I would use a dual loop if possible and put the CPU and GPU on separate loops.
Just One Man's Opinion.
																		Methodical
Are these temps with fans at low rpm and/or during benchmarking tests? I ask because I know some folks goals are to have low rpm fans and low temps.normal temperatures are very low. 40 45°C.
if oc is down...default bios...temperatures under load are 85-90 °C...everything is ok, but I use just over half the power.
It only reaches 105 degrees at maximum overclock and under load with absorption of around 320-330 watts.
I want to understand if the double pump is needed or a single pump is enough to overclock to 330 watts and keep it below a constant under 90 °C
Dieser Beitrag wurde bereits 6 mal editiert, zuletzt von »Methodical« (5. April 2024, 13:13)
																		DeDog
																		DeDog
incl. Value added tax IT 22%: 90,99 EUR
																		DeDog
																		Remayz
																		DeDog
																		Remayz
																		DeDog
