Sie sind nicht angemeldet.
J-MI
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Speedy-VI« (21. August 2024, 02:53)
J-MI
J-MI
J-MI
The setup is a little tricky. In the HFN Alarm tab under Signal Output, click the button that says, “Generate high flow sensor [53068] signal (DP Ultra, Inner Diameter <7mm)”. This will cause the HFN to generate a timing signal that emulates the #53068 flow sensor. #53068 is a discontinued flow sensor model, but it does not matter here. Then in the D5N Sensors tab, select the 2nd sensor and in the section below, under Sensor Type select Aquacomputer high flow [53068]. For Medium/Coolant select DP Ultra, and for Fittings Type select >7mm. Now the HFN is set up to emulate the flow rate signal for the #53068 flow sensor and the D5N is set up to receive that signal. After doing this, the HFN flow rate is available to the D5N and can be displayed in the D5N display templates that include flow rate. As an added bonus, the D5N Alarm will now use the HFN flow rate instead of the very inaccurate virtual flow rate.
