• 08.02.2026, 09:20
AMPINEL: Latest information about the product and launch date
Gestern, 16:35
(Go to the original product announcement)
It's been a long journey, but now the time has come: AMPINEL will be available to order in our shop on Monday, February 9, 2026, from 4 p.m. (CET / UTC+1) onwards.
Anyone who has followed developments is aware that there was a delay of around three months at the end. The reason for this is that AMPINEL operates at the cutting edge of measurement technology in many areas, and we want to deliver a product that works reliably and offers real additional value.
Due to the significantly expanded range of functions and the additional development costs associated with this, a price adjustment was also necessary. AMPINEL will go on sale at a price of EUR 99.90 (incl. 19% VAT).
AMPINEL is a power supply balancer for graphics cards with 12V-2x6 power connector, explicitly developed and released for NVIDIA RTX 4000 and RTX 5000 series cards. Release for AMD cards is currently being worked on and will communicated after successful validation.
AMPINEL works in a much more complex way than other solutions on the market. As a balancer, AMPINEL actively regulates the current on the individual rails, thereby reducing power losses at the connector. This may sound simple at first, but requires highly complex measurement algorithms, as AMPINEL does not simply equalize the current on all lines, but also takes heat generation at the connector into account. To do this, AMPINEL determines the quality of the connections, which is only possible through a complex analysis of the measurement data. Since the power consumption of graphics cards is highly dynamic and the current may change significantly in the range of microseconds, this has been one of the most difficult tasks in our development.
By evaluating the measurement data, AMPINEL can determine not only the contact resistance to the graphics card, but also in the path from the power supply to AMPINEL. The results are visualized in the aquasuite software, where different colors represent resistances in a schematic of the corresponding connectors, thus enabling easy diagnosis in the event of problematic contact resistances.
To enable optimum protection of the graphics card, the following objectives have been defined for the AMPINEL control logic:
1. The current must not exceed 9.2 A at any of the contacts (plus 5% control tolerance).
2. The total power loss at the connector should be minimized respecting this specification; the current is then balanced accordingly.
3. The power loss of individual contacts must not exceed a specified power rating.
4. The maximum power loss at the balancer must not be exceeded.
5. The temperatures at both connectors and at the balancer are monitored.
The integrated monitoring is extremely comprehensive and includes voltage and current measurement on all 6 channels.
The multi-level alarm management system is also comprehensive. This enables a finely graded response to unwanted situations.
In addition to visual and audible alarms, a wide range of actions can be defined. These range from pop-up messages to automatic termination of software that causes a high GPU load, sending of definable hotkeys, shutdown of the PC, switching of alarm outputs, switching off of the Sense lines, and hard shutdown of the graphics card power supply via AMPINEL.
Overall, the alarm system is controlled in 8 stages, for which the corresponding escalation levels can be defined.
The balancer can be limited to a control range of 0-100%. If you only want to use the alarm functions in the event of an alarm and do not want to use balancing, you can configure the control range to 0%.
The maximum power reported by the power supply via the Sense contacts can optionally be reduced by AMPINEL to put the graphics card into a more economical operating mode. AMPINEL supports power levels of 600 watts and 450 watts.
AMPINEL has an OLED display, a button, and multicolor lighting. The data to be shown on the display can be selected in aquasuite. Several alternating views are possible. Currents, voltages, and other AMPINEL measurements are quickly visualized and can assist in troubleshooting the cable.
In addition, a variety of PC hardware data can also be displayed on the AMPINEL display, and text and graphic logos can be customized according to your preferences.
The integrated lighting can display a wide range of measurement data, for example, the current power consumption of the graphics card can be visualized as a colored bar graph.
Of course, all other aquasuite functions can also be used with AMPINEL. These include, for example, extensive logging and evaluation options, the creation of almost any function in the Playground, and individually customizable overview pages.
We are delighted to have finally brought this project to a successful completion and look forward to receiving your feedback. An initial test was already published by igor’sLAB in October.
In the test, AMPINEL achieved a sensational 5/5 stars and the Editor's Choice award. The hardware has not been changed since the test, but the software and firmware have been significantly improved once again. We will continue to take your feedback into account and incorporate it into our product maintenance in the future.
AMPINEL is available in two different configurations: Type A and type B. The difference is the connector orientation of the 12V-2x6 connector for the graphics card, corresponding to the different assembly variants of the graphics card manufacturers. Please select the variant that matches your graphics card; the connector orientation cannot be changed.
It is important to connect AMPINEL directly to the graphics card. Do not use extension cables or adapters between AMPINEL and the graphics card. This is the only way to measure the relevant contact resistances on the graphics card!
The following technical drawings can be used to check whether the adapter can be installed in your setup without restrictions. The drawing is to scale and can also be printed out for better evaluation. Please ensure that the actual size is used in the print settings without rescaling.
Technical drawing type A /// Technical drawing type B
Techncal details:
Graphics card connector orientation type A or type B, fixed
Input connector: 12V-2x6
Output connector: 12V-2x6
Maximum power input/output: 650 W
Nominal Voltage: 12 V, alarm if lower than 10 V
Nominal current per rail: 9.2 A, alarm if higher than 9.6 A for 8 seconds, immediate shutoff if higher than 20 A
Maximum total current: 55 A, alarm if higher than 57 A for 10 seconds
Ambient temperature range: 15 °C - 45 °C
Maximum temperature AMPINEL: 90 °C
Maximum power dissipation AMPINEL: 6 W, short-term 15 W for less than 10 seconds
Display: OLED 128x64 pixels, 0,96" black/white, 10 configurable display pages
Illumination: 8 RGBpx LEDs, configurable
Interfaces (miniature connectors):
- USB
- External temperature sensor
- Power switch output for motherboard (Signal 1)
- Speed signal / switched signal for external alarm (Signal 2)
Scope of delivery:
- AMPINEL
- one internal USB cable, length ca. 100 cm
»Shoggy« hat folgende Dateien angehängt:
  • AMPINEL A.PDF (131,5 kB - 155 mal heruntergeladen - zuletzt: Heute, 09:19)
  • AMPINEL B.PDF (132,97 kB - 140 mal heruntergeladen - zuletzt: Heute, 09:20)
KuraiShidosha
Gestern, 17:28
Looking at the schematics, I am doubtful this will fit in my Bykski waterblocked MSI 5090 Gaming Trio OC
aquafan
Gestern, 17:36
Incredible news, finally, thank you! I assume 5090 SUPRIM is TYPE A? Thank you so much
ksenchy
Gestern, 17:57
How long is the included update period for aquasuite software?
Gestern, 18:00
Based on this photo, it is type B.
18 months
Tomace91
Connector Type
Gestern, 19:33
I assume ASUS RTX5080 TUF OC is TYPE A, right?
Picture about card
ksenchy
Gestern, 20:22
How does this product handle in Linux. I do have win11 to configure the alarms and the ability to turn off the GPU. Will this work in Linux - no software running as it doesn't support linux.
Gestern, 21:39
This is exciting news, Shoggy - Can you provide any information about availability from US vendors like Titan Rig, Performance PCs, and ModMyMods? Do we have to order directly from Aquacomputer and pay for international shipping?
erief
Gestern, 21:58
Hello, with an Ampinel A (Asus RTX 5090), will a dual-tower heatsink cause any problems?
junluo168
Gestern, 23:20
It would be great if a list of brand and model of 5090 cards and their correct type can be provided. Should help to confirm the connector type and reduce incorrect orders.
So far it looks to me most popular models of ASUS and GIGABYTE are Type A while PNY and MSI are type B.
WIll be ordering on day one!
juanma1358@yahoo.es
Gestern, 23:28
HI, I would like to know if will be posible monitoring the ampinel with hwinfo64. Thank you
junluo168
RE: Connector Type
Gestern, 23:31
Picture about card
I believe this is TYPE A. (Do you need one for 5080?)
Looks to me in
TYPE A, the 12 pin power connector is between PCB and the 4 (smaller) sginal pin. Clip is cloer to the PCB board.
TYPE B, the 4 (smaller) sginal pin is between PCB and the 12 pin power connector, Clip is away from the PCB board and closer to heatsink.
ViRuS2k
What connector type for Asus Astral 5090 ?
Heute, 00:52
What connector do i use for Asus Astral 5090 OC (i think its Type A)
need ampinel sticking out the top of the card so power cable 12vhpwr can be connected to the back of the Ampinel device from the back of the card.
and finally need to know if there will be a uk distributor for this or i can pay the tax if its only sold in Germany to uk...
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »ViRuS2k« (Heute, 07:13)
Gilgallard
Lifesaver
Heute, 02:17
Thank you for developing this device. It is a real lifesaver. We invest large amounts of money into our rigs and then we have to fear if it will all melt at some point.
I will surely buy it as soon it is available (on Monday). :)
BTW, I hope that you can help me with the connector type. My card is the Inno3d RTX 5090 X3 and I think that the connector for that card should be type B. What do you think?
