Sie sind nicht angemeldet.
KuraiShidosha
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »KuraiShidosha« (23. Oktober 2025, 04:01)
cool&quiet
There have been a huge number of updates since 2016, far too many to list. I don't know how many of them are relevant to an Aquaero 6 Pro. I suggest looking at the second post in this thread that contains the Change Log for recent updates going back to Aquasuite version X.78 and has links to the Change Logs going back to 2016. There have probably been some firmware updates for the Aquaero 6 Pro. Also, the current version of Aquasuite requires Microsoft .NET 8.0. I took a quick look and found significant updates for the Aquaero 5 and 6 in early 2017 which I have pasted below. Aquacomputer does a pretty good job of maintaining the Change Log, although technical details are often not fully described.The versions read: firmware 2009, aquasuite 2016-5.3. It's running just fine. Never had any issues that I'm aware of. So is the update worthwhile? Is any updated or added functionality expected?![]()
cool&quiet
Thanks. I might go with the update even though I don't have — nor unlikely will have — water cooling in my system, as it sounds like many of the updates have to do with its functionality. A tenner ain't that much for a fresh GUI and a firmware update, which is always welcomed. I wonder if I'm able to bring back the settings from such an old version, but I'll find out by latest should I snag it...There have been a huge number of updates since 2016, far too many to list. I don't know how many of them are relevant to an Aquaero 6 Pro. I suggest looking at the second post in this thread that contains the Change Log for recent updates going back to Aquasuite version X.78 and has links to the Change Logs going back to 2016. There have probably been some firmware updates for the Aquaero 6 Pro. Also, the current version of Aquasuite requires Microsoft .NET 8.0. I took a quick look and found significant updates for the Aquaero 5 and 6 in early 2017 which I have pasted below. Aquacomputer does a pretty good job of maintaining the Change Log, although technical details are often not fully described.The versions read: firmware 2009, aquasuite 2016-5.3. It's running just fine. Never had any issues that I'm aware of. So is the update worthwhile? Is any updated or added functionality expected?![]()
General changes for the aquaero 5 and 6 series
In the aquaero, the aquabus is checked for resource conflicts now. Problems are marked with a warning symbol and further information about a conflict will be displayed too. This helps to keep track of complex systems and to understand where a displayed sensor value is coming from. Devices are highlighted in red if they are not connected anymore. Devices that had a communication problem in the last 4 hours are highlighted in yellow.
In the aquaero firmware the aquabus administration has been completely revised. Devices get mapped much faster into the system now. In addition, we have already integrated upcoming devices. As already mentioned: make sure to update the firmware of devices that are connected via aquabus.
As of now it is possible to connect two aquaero slave devices to an aquaero master device. Since a slave device offers no USB communication the aquabus ID for a second slave device must be set by placing a jumper onto temperature sensor port 8. A slave device can also monitor a flow sensor now and transfer its value via aquabus to the master device.
Also new is that we moved the option to connect a second flow sensor from fan port 1 to the aquabus lowspeed port which had no function lately. This way fan port 1 can be still used for other stuff when connecting a second flow sensor.
In addition, a new status page has been programmed which shows the current profile, number of alarms/warnings and the current alarm level. To keep it simple we no longer display the 12V on/off messages.
Changelog for aquaero 5 and 6
Bugfix: some text and menu entries have been improved
Bugfix: non-connected temperature sensors with an offset are now automatically hidden
New: administration of aquabus resources and status information
New: the aquabus communication has become much more robust compared to previous implementations
New: two aquaeros with slave firmware can be connected to a master device
New: a second flow sensor will be connected to the aquabus lowspeed port now
New: status page for profiles, alarms, warnings, alarm levels
New: 12V on/off messages are no longer displayed
Changelog for aquaero 5 and 6 with slave firmware
New: improved aquabus communication
New: value of a connected flow sensor is transmitted via aquabus
New: up to two aquaero slave devices via aquabus
New: jumper on temperature sensor 8 selects aquabus address for second slave device
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »cool&quiet« (16. November 2025, 19:31)
Jeff3F
julien1428
Montag, 5. Januar 2026, 19:30
Mittwoch, 7. Januar 2026, 04:47
I am curious. What exactly what wrong with the RGB colors? I have 2 x Farbwerk360s in one of my computers and have never had any problem with them.Thank you for fixing this issue. I hadn't changed the colors of my RGB lights in a while so Im not sure exactly when the problem started, but this update fixed it.
KuraiShidosha
vertic
Just installed the latest nvidia driver (591.74) and the issue is now fixed. It was the combination of X.85 and the previous driver (591.59) I had that didn't work together it seems.Is there a way to downgrade to the previous version? X.85 no longer has GPU Power data, and it was there in X.84![]()
tistou77
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »tistou77« (21. Februar 2026, 09:19)
fpompert
), so I assume some regression occurred here.Firmware 2104 is still the latest one.Is it necessary to update it (currently version 2104) if a new version is available ?
You can find the changelog here.What is new in x.86? ?
No problem here. Maybe you are doing something wrong. The entry "user defined logo" must be set for the idle and/or standby page.I have an issue with my Aquaero 6 Pro, where Aquasuite (ver X.86 and also earlier) cannot upload new custom logo's to the device it seems.
