• 27.02.2026, 23:46
Remayz
Gestern, 09:41
I have started having a lot of issues since X86 that looked to be the service not starting but seem to be the application itself in the end.
At boot, the dashboard will only show hardware sensors. All the virtual and software ones won't be active. Usually that's when the service is not running, but when i look in windows services, it is. If i wait long enough, aquasuite will popup the message saying the service is not active etc..
If i just close aquasuite and restart the app, it will pick up the service and display everything.
I know the service works because during boot the fans run at their fallback speed, a bit faster than usual, and after i log into windows, they slow down and get controlled. So there is something here that seem to make AS not communicate with it.
Remayz
Heute, 17:18
Well, first boot with X87 and it seems solved :D
