• 04.03.2026, 01:27
Remayz
Donnerstag, 26. Februar 2026, 09:41
I have started having a lot of issues since X86 that looked to be the service not starting but seem to be the application itself in the end.
At boot, the dashboard will only show hardware sensors. All the virtual and software ones won't be active. Usually that's when the service is not running, but when i look in windows services, it is. If i wait long enough, aquasuite will popup the message saying the service is not active etc..
If i just close aquasuite and restart the app, it will pick up the service and display everything.
I know the service works because during boot the fans run at their fallback speed, a bit faster than usual, and after i log into windows, they slow down and get controlled. So there is something here that seem to make AS not communicate with it.
Remayz
Freitag, 27. Februar 2026, 17:18
Well, first boot with X87 and it seems solved :D
Klirng
Samstag, 28. Februar 2026, 17:06
The antivirus recognized the update as a PDM:Trojan.Win32.Generic ?(
Remayz
Samstag, 28. Februar 2026, 18:32
that's still the winring0 hardware monitoring. you have to disable all hardware monitoring within aquasuite options. I have it all disabled and windows defender doesn't complain
hvckmvn
new driver
Gestern, 04:06
updates on ms driver status? have bought 2 quadros, 2 farbwerk360, and purchased updates for my newer quadro hoping these issues get worked out... i cannot continue to buy into updates supporting aqua when the updates arent containing the fix i need
Changelog
aquasuite X.88 (2-MAR-2026)
  • Bugfix: aquasuite tray icon, profile switch
AMPINEL Firmware 1002:
  • New: Distinction between 300W, 450W and 600W input power cables
willh
Gestern, 16:19
Are we any closer to shipping a non-vulnerable version of Aquasuite?
The suggestion to not use basic functionality in software I am paying for, as a workaround, is not good enough.
I get this every time I start my PC...
