• 23.01.2026, 08:35
MrRCS
update aquaero 3 -> 4?
Samstag, 30. Juli 2005, 01:59
i have the aquaero 3.07, firmware 3.10D.
Can I update to firmware 4.xx ?
Can I use aquasuite BETA 4.31 ?
How ?
thanks.
Top_Nurse
Re: update aquaero 3 -> 4?
Samstag, 30. Juli 2005, 02:29
Go over to the [H]ardForum as we have a nice little thread with all that info for you. The directions you will find there was done by Shoggy and many of us have flashed successfully.
MrRCS
Samstag, 30. Juli 2005, 04:28
http://www.hardforum.com/showpost.php?p=…&postcount=1760
http://www.hardforum.com/showpost.php?p=1027800454&postcount=2285
Max_Payne
Samstag, 30. Juli 2005, 14:26
Yes you can ;D
Read the thread from Shoggy
--> http://www.hardforum.com/showpost.php?p=…&postcount=1760
Gruß Max Payne
