• 29.03.2026, 08:07
stu_allen
Re: Dual Aquadrives
Freitag, 9. September 2005, 15:56
Zitat von »Top_Nurse«
Found some pics of what I needed, but now need to find out if the Dual Aquadrive has only one water path from front to back or does the channel cross back and forth? Trying to decide if I would get better cooling with four Aquadrive's or two Dual Aquadrive's?
1 cooling path, you would get better cooling with 4x singles, but only fractionally as HDs dont put out that much heat anyway.
You will get a LOT better flow with 2x duals rather than 4x singles IME.
